ABS sensor picture?
HoustinoJillian
name's JUSTIN
usa
can anyone post a picture and description of the ABS sensors? i'm trying to find out whats causeing the light to be on. also, are the front/rear the same?thanks
The actual sensor is inserted into the hub and is very close to the notched sensor ring and has a wire attached to it. The sensor is a proximity sensor that detects metal and sees the gap on the sensor ring.
DHMag
Free At Last
InCahoots, Texas
a few suggestions on where to look for possible causes of the light:
1) the wiring harness that plugs into a relay box right next to the ABS motor. notorious to rub a hole thru the shielded wiring.
2) the ground wire attached to the core support.
somedude_001
Western NY
you could go to autozone and have them scan the ABS module for free? or guess whichever you choose.
there are 2 OBD connectors under the hood one is for engine and trans, the other is for ABS it has a red cap on it (if the cap is still there)
HoustinoJillian
name's JUSTIN
usa
autozone will scan it for free? didnt know that... now to find an autozone locally...
