ABS light stays on-what's wrong?
Tomuza
Williamston S.C.
Does the light stay on continuosly (no power?) or does it flash...check codes for abs on shotimes FAQ for flashing code. Others on here will know alot more than I do. Good luck ! :)
naval-avi8or
Chesapeake, VA
I had the same problem with mine after it set for about a week in Pnsacola FL. I diconnected the ABS computer harness and reseated it, didn't help, next to the ABS computer is a relay for the ABS sytem in my car the relay was for one mounted upside down and moister got in and corroded the contacts. I maneged to clean enough off it out (its hard to do) to get a good connection and that fixed my problem. They relay may not cost very much so it may be easier to replace if thats your problem.
poffffd
