ABS light problem
93MTXSHO_STUD
lubbock, TX
My abs light has been on for some time now and i was wondering if anyone knows what might be bad. I tried putting a different ABS control unit in and the light still is on. It seems to go on whenever i geet about 20 or so. Do bad wheel sensors make the light go on? I can assure you this is not because of my battery. I have a full charge. Any suggestions?
CerberuS
300 HP N/A SHO
Granby, QC, Canada
prolly a bad WSS , wheel speed sensor , thats used for abs.
takes a certain speed before he lights up the thing. Theres a way to pick up the ABS codes in the forums , and places to diagnose em.
What is does? nothing , you dont have ABS , just regular brakes.
93MTXSHO_STUD
lubbock, TX
does anyone know where this abs tester module is located? I assume its not the same one as the check engine module.
projectSHO89
SHOless In St L
It is mounted to the shroud right nect to the EEC test connector at the firewall.
Look under the hood....
Steve
EMB2580
Mike is a L O S E R
Zion, Il
My diagonostic connector for the ABS system on my '90 is right behind the MS and it's red, so it the protective cover. Were just the G I's red? IIRC, I thought they are blk on the G II's.
93MTXSHO_STUD
lubbock, TX
ok i pulled some codes and this is what i got. 34,35,38,37,44,61,63,78. As I recall, this light came on right after I took the radar out to replace the AC Condsenser. I dont know if there is anything in the abs around that area that I could have messed up. I looked, and couldnt find any unplugged connectors. My abs has been off for a while, any help would be greatly apperciated! It's usually always on.... though i think a couple of times it didnt come on.
EMB2580
Mike is a L O S E R
Zion, Il
Ok, according to the list 34, 38, 44, 78 all say left rear SS, 35 is left front SS, 37 is right rear SS, 61 is FLS circuit, and 63 is pump motor speed sensor. I have no idea why it has several different codes for the same thing. Mine was the same way. But most of the time the SS's are more that likely dirty. But, I've heard that it is almost impossible to get the off to clean them w/out breaking them.:cuss: This is besides the point, but I've also heard the ABS system on these cars was not the greatest to begin with. Personally, I like the feel of conventional (locking) brakes. You could just do what someone did to my car way before I got it: take the bulb out, LOL.:naughty:
93MTXSHO_STUD
lubbock, TX
So does anyone know what could be wrong? I read somewhere that a ground could be bad? Whats near the radiator that could go bad. I had to unplug some stuff around there. after i put everything bad together the light came on. i think it has something to do with that?
EMB2580
Mike is a L O S E R
Zion, Il
The ABS "brain" is to the right of the radiator, between the radiator and the air filter housing box.
smak
toronto
i thought the ccrm was between the rad and airbox.
can you be mroe specific?
EMB2580
Mike is a L O S E R
Zion, Il
The CCRM is a smaller box that lays flat underneath the plastic cover on top of the radiator. The ABS "brain" is larger and and stands upright next to the radiator.
smak
toronto
sweet.. anyone know if thats what i have to unplug to disable my abs without sparking the anti-lock light on my dash?
its either the abs brain or the abs motor from what i understand.
thnx for that clarification emb2580
EMB2580
Mike is a L O S E R
Zion, Il
Your welcome. LOL, I have no idea how to disconnect it but like I said in an earlier post to this original thread, someone pulled the ANTILOCK bulb out on my car, but it's a PITA to get the dash out.
93MTXSHO_STUD
lubbock, TX
ihmmm... are we thinking about the same thing??? Are you talking about the ABS main control unit the thing kinda underneath the air box and to the leftt? The thing with about 24 or so pins in it? If so I replaced that and my problem still occurs. i think im going to clean the sensors and make sure all the plugs are cleaned. i really dont know what else to do. Im not taking my car in to have someone look at it, so i guess ill do the best i can.
