ABS Code 22
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
I just had the SHO in for test fitting for teh y-pipe and it came back with an ABS code of 22. I am not sure what this for or what to cehck out. Any ideas?
Diagnostic Trouble Code Table 1994
AIR BAG DIAGNOSTIC MONITOR DIAGNOSTIC TROUBLE CODE PRIORITY TABLE
Priority Code Component/Fault Description
Highest - No Air Bag Indicator - Inoperative Lamp Circuit or No Ignition
Voltage to Air Bag Diagnostic Monitor
Continuous Air Bag Indicator - Air Bag Diagnostic Monitor
Disconnected or Inoperative
12 Low Battery Voltage
13 Air Bag Circuit Shorted to Ground
14 Primary Crash Sensor Circuit Shorted to Ground
21 Safing Sensor Not Mounted to Vehicle Properly
22 Safing Sensor Output Shorted to Battery Voltage
23 Safing Sensor Circuit Input Feed/Return Circuit Open
24 Safing Sensor Output Feed/Return Circuit Open
32 Driver Side Air Bag Module High Resistance or Open
33 Passenger Side Air Bag Module High Resistance or Open
34 Driver Side Air Bag Module Circuit Low Resistance or Shorted
35 Passenger Side Air Bag Module Low Resistance or Shorted
42 Center Radiator Primary Crash Sensor Feed/Return Open
44 Center Cowl Primary Crash Sensor Not Mounted to Vehicle Properly
45 Center Radiator Primary Crash Sensor Not Mounted to Vehicle Properly
51 Diagnostic Monitor Internal Thermal Fuse - Fuse Blown Due to
Intermittent Short to Ground
52 Backup Power Supply - Voltage Boost Fault
53 Primary Crash Sensor Circuits - Resistance to Ground or Air Bag
Diagnostic Monitor Failure
Lowest - Rapid Continuous Flashing of Air Bag Indicator (No DTC) All Primary
Crash Sensors Disconnected
AntiLock brakes DTCs ’95 Taurus
DTC 31 Open or short circuit LH front sensor, wire harness
DTC 32 Open or short circuit RH front sensor, wire harness
DTC 33 Open or short circuit RH rear sensor, wire harness
DTC 34 Open or short circuit LH rear sensor, wire
DTC 35 Open or short circuit LH front sensor, wire harness, teeth on front brake anti-lock sensor indicator, sensor air gap too small/large
DTC 36 Open or short circuit RH front sensor, wire harness, teeth on front brake anti-lock sensor indicator, sensor air gap too small/large
DTC 37 Open or short circuit RH rear sensor, wire harness, teeth on rear brake anti-lock sensor indicator, sensor air too small/large
DTC 38 Open or short circuit LH rear sensor, wire harness, teeth on rear brake anti-lock sensor indicator, sensor air too small/large
DTC 41 Missing sensor signal LH front sensor (missing front brake anti-lock sensor indicator
DTC 42 Missing sensor signal RH front sensor (missing front brake anti-lock sensor indicator
DTC 43 Missing sensor signal RH rear sensor (missing rear brake anti-lock sensor indicator
DTC 44 Missing sensor signal LH rear sensor (missing rear brake anti-lock sensor indicator
DTC 55 Missing sensor signal LH front sensor (long term failure).
DTC 56 Missing sensor signal RH front sensor (long term failure).
DTC 57 Missing sensor signal RH rear sensor (long term failure).
DTC 58 Missing sensor signal LH rear sensor (long term failure).
yzstud
< my kawi
Minnesnowta
ABS DTC 22= open or short circuit- LH Front Inlet Valve, wire harness
Measure resistance between breakout box pins 3 and 20.
Is resistance between 5 and 8 ohms?
YES -- Go to BB4. See: BB4 - Check Circuit 495
NO -- Go to BB3. See: BB3 - Check LH Front Inlet Valve
BB4-- Disconnect valve block connector from wire harness.
Check for continuity between breakout box pins 20 and 60.
Is continuity present?
YES -- Service circuit 495 (T).
NO -- Reverify DTC 22.
NOTE: If other DTCs are output, service next DTC
BB3-- Disconnect brake pressure control valve block 16-pin connector.
Valve Block Connector
Measure resistance between pins 14 and 1.
Is resistance between five and eight ohms?
NO -- Replace brake pressure control valve block.
hope this helps, if you have any q's, just ask
Randall
San Jose, California
.....two years later......
Hey Matt, remember me, :)
Anyway, I got the same code even though the light never comes on once the car's initial start up bulb check happens. I also got codes 44, 43, and 63. My car has had the pedal going to floor at random and then working perfectly the rest of the time. My questions to you are did you have any stopping issues when the light came on, and how much did this part cost, and do you guys sell it at SHOsource?
Thanks!
platoribs
Live to Drive
Plat0ribs House of SHO,il
and another year and a half further down the road. Matt didja have a shop do the pump R&R or did you do it yourself. How much did you pay/curse?
I'm looking at a pump job to fix my ABS...
LOUDSHO92
Sponsoring Vendor
I did end up replacing the pump myself with a unit from Mike at SHO Source. It fixed the problem. The only issues I had were lining up the brake lines. I had to first hold the unit to get the lines to line up and then mounted it.
You also need an ABS bleeder.
