Shostuff,
You will have to look at a service manual for your model year. There a couple of impact sensors up front mounted to the radiator support. There are also connections for the airbag in the "clockspring" module, which is also under the steering wheel.
There may also be one or more "harness to harness" connections. Most of the "under the hood" harnesses flow through the firewall at the 60 pin connector.
The clockspring and the impact sensors are the most common failures. To get at the clockspring the airbag has to be removed.
Again, I warn you, do NOT fool with any airbag connection unless you have disconnected the battery and waited for a few minutes. A small amount of static electricity can set off the airbag.
The airbag is deployed by an explosion, the force generated is tremendous, and the gas that inflates the bag is super hot. If you remove the airbag always point it away from you, put it facing up, and put it someplace safe.
Handle it as if it were a bomb, because it is! rangerj
