About wheel bearings.
FastAndFurious
Washington
Get the BCA/National bearing for $10 more.
Is it just a bearing? I need a hub assembly because I'm pretty sure the hub is messed up too. If it's a hub assembly for the price, link please :thankyou:
Oh and sry for the title. I should have said about hub assemblies.
You do not want to buy a bearing and hub asm because the bearing need to be pressed into the knuckle first, then the hub needs to be pressed into the bearing - all using the proper bushings to avoid damaging the bearing of course. If the bearing is already on the hub, then there really is no way to get it installed w/o damaging the bearing.
