about gaskets
kevingotashotoo
200 or so ponies
peterborough,ON canada
im just wondering and if anyone has done it,
if i took my intake gasket and traced them on gasket paper and cut em out would this work, and also any of my other gaskets
thanks
projectSHO89
SHOless In St L
Sure, it can work.
For intakes gaskets, I usually just clean them thoroughly, then spray them with some flat black spray paint.
The gasket is bad only if the black surface has chipped or peeled and the shiny surface underneath is visible.
The spray paint usually makes a good repair.
Steve
yamahaSHO
E85 whore
Arkansas
If you're replacing a paper gasket with another paper gasket, it will work fine. It will work on the intake-to-head too, but then it could be a pain to remove the intake and clean it up everytime.
jedhead
westminster,ca
My throttle body gasket was made from a manila folder. I have used manila folders for paper gaskets for many years.
Bob
