One day after having my tranny fluid power plurged flushed, the shifting in the ATX is all wacked out at times.
At first, I'm like wow, the shifting is much better now after the flush, then all of a sudden, I'm getting stuck in 4th gear. RPM may be around 3000 and the speedo around 80mph. I guess it's getting stuck in 4th because all the car will do from this point is accelerate smoothly even under heavy acceleration. It accelerates good but the gear doesn't shift. And the rpm won't go pass 4000.
So, when this happened the first time, for whatever reason I decided to reset the idle. Took it on the highway, and the shifting was again better than ever before the flush. Then after another hour of driving, I'm getting stuck in 4th gear.
I'm thinking that it could be a bad motor mount which I do have a very bad motor mount? Or maybe the TPS? But I'm thinking how could these be the problem one day after a flush. As I slow down to a stop the car bucks from the atx trans shifting down. The easiest explanation will be to get the tranny rebuilt, but I want to find out why is this happening a day after a fluid flush? Also, different is that I hear this whistle noise coming through the top of the engine as I accelerate. And this too I don't think was there before the tranny flush.
