A/C System Overhaul
Spring Hill, FL
Just wondering how difficult it'll be and if I'm forgetting anything. I'm looking to replace the seals in/around the compressor like the shaft seals and the main gaskets. I also have all the o-rings for the couplers. Anything else I should look for/do/get? Since I'm opening the compressor I'll probably need new oil, not sure what kind I should get if there's different kinds. Anything else I'm skipping or forgetting? I have a little A/C right now, but if I'm gonna lose gas milage for using I might as well be cool and not just knock the edge off the heat. Thanks!
projectSHO89
SHOless In St L
New accumulator, new liquid line with the correct orifice for the refrigerant to be used, oil, refrigerant, vacuum pump, gauges, etc, etc
