A/C Low pressure charging valve Q
hawkeye18
Sorta cares
Norfolk, VA
Ok: first, I did search. I didn't find anything that specifically helped, though it is apparent that rangerj has firmly established himself as an A/C guru!
Anyway, My wife's 95ATX seems to have developed a leak at the low side charging port. The port itself is way bigger than a schrader valve, but nevertheless that's how rangerj described it. Is it possible to replace just like a schrader valve core? It doesn't look like one when I look at it. There's a big rubber thing in the way... can you get that out with a pick? I'd try but I don't wanna f**k anything up yanno... or am I gonna have to replace the whole dryer/tube assembly? Yeah, I mean I probably should, but I'm broke and that's a lot of work... anyway, any help would be much appreciated. Thanks!
I'll sho u
saint john,nb,canada
not all low side ports are like a shrader valve. Some are just a check valve that seats against a rubber insert, thoes are not replaceable. Try quickly depressing the valve, quite often there is a piece of dirt causing the leak, if that does not work, the pipe with the low pressure port will need to be replaced. If the port is like a shrader valve, it unscrews just like one but is a bigger size.
JustinSane
SHO OFF
PA SHO Shop
yep^^ push down the ball and let some freon and oil rush out that should flush any dirt or other debris.
hawkeye18
Sorta cares
Norfolk, VA
hmm, yeah, didn't read this in time: we destroyed the rubber. It had a huge tear in it to begin with (well, huge for the valve, I guess). So, the valve is completely hosed now. Can it be hoes tiem nao pleas?
