A/C is blowing thru defrost vents
SHOstuff
Houston,TX.
My a/c just started doing this yesterday where it spontaneously started blowing thru the defroster vents. I have to continously mess with the buttons to get it to blow back to the vents. I've searched the site for anyone with an '89 sho with an eatc and I didn't find any with mu issues. Is there a way to test my model to see whats wrong?
turbosho
Dallas
the door that controls that is behind the glovebox on the left hand side. you will see the grey plastic arm connected to a diaphragm. these arms frequently break and/or the diaphragm's rip due to old age.
SHOstuff
Houston,TX.
Would I see that easily and repair it easily?
SHOstuff
Houston,TX.
another thing that it does is swsitch back to vents randomly. i would have to mess with to go back to vents sometime also. so...what do y'all think?
SHOstuff
Houston,TX.
Just randomly. I first noticed when I was on a bumpy road and it switched to vents and the other when just driving regularly. I can mess around with the buttons and it'll switch to vents sometimes too.
ShadetreeSHOguy
Postwhore
Dallas, Ga
It almost sounds like your EATC is on its way out.....
SHOstuff
Houston,TX.
Ok. So thats jist a matter of getting another then. Thank you shadetree! Have you had this experience before?
ShadetreeSHOguy
Postwhore
Dallas, Ga
Ive seen it before on another sho, not mine personally.
Mine goes to defrost when you get on the throttle. Mine is apparently due to a vacuum leak at the firewall.
Good luck :thumb:
SHOstuff
Houston,TX.
Before I get this eatc, I'd like to make sure that's it. Can '89 model eatc run test on ours, if not, what's a way of telling the difference a bad eatc and a bda given the symptoms I gave?
SHOstuff
Houston,TX.
Turbo! You were right. That grey plastic arm was the culprit and it did break. Do you know of a way to fix it or anyone else on here know?
nickysho1
jusayin!
MI
hey does anyone on here know what a SHO engine and 5 speed transmission goes for? they both work great. 207.000 miles on them both. all original.
SHOstuff
Houston,TX.
I've since fixed my issue but I was wondering if it can be replaced and how? Because i'm doing my heater core, again, and I wanted to take care of all that while i'm in there.
