A/C field coil connector
bittertech
Atlanta
So i tried troubleshooting my A/C, I've got a replacement clutch assembly, hub, shims, field coil ready to be slapped in -- but I'm afraid I might have 2 issues at hand. Try as I might, I could not get any voltage thru the field coil connector. The condesner was jumped. I'm wondering if I mighta missed a wiring harness, short of tracing back the wire through the loom, anyone know where the field coil wire ends up? Thanks.
projectSHO89
SHOless In St L
1990 AC coil power
Power is provided to the EATC head unit from F17.
Power from EATC is to the cycling switch on the accumulator (not the condensor, that's in front of the radiator) on the GRN/PPL wire.
If manual A/C control, wiring is the same color codes.
Via closed cycling switch, power is then sent via PNK/BLU wire to IRCM pin 21.
Internal to the IRCM, a solid state relay switches power to the clutch coil under control of the PCM:
Relay "coil" power - IRCM pin 12 BLK-ORG
Relay output to clutch coil IRCM pin 23 BLK-ORG
PCM input to energize relay - IRCM pin RED
As seen, the cycling switch is only part of the control circuit, the rest is in the IRCM and is controlled by the PCM.
Steve
poffffd
