My '94 SHO ATX 3.2L A/C compressor clutch wiring harness has been cut. I think I found a replacement connector that I can solder back to the car wiring harness. This is a 2-wire connector and I ohm'd out which wire on the car wiring harness is Gnd/Neg, so the other wire must be positive and will be the switched/signal wire to control the clutch. Does the polarity matter to the A/C compressor clutch? I'd like to know if the positive must be connected to the top or bottom compressor terminal or the terminal nearest the spring clip on the connector.
