PBCrunch
I just got a 1994 Ford Taurus SHO MTX for free. The car has some issues though.
The car has a blown out passenger front tire. For the time being I think I can get the car mobile again for the least amount of cost by buying a wheel and tire from the junkyard. The car has no spare tire. Will regular Taurus/Sable fourteen or fifteen inch wheels clear the front brakes on an SHO? What about the rear brakes?
The showstopper is the fact that the air conditioning compressor clutch is stuck. If the A/C ran on its own belt like it does in my Dodge this would be no problem. As most of you know the A/C compressor and the alternator run on the same belt on the SHO V-6. Could someone describe the procedure to remove the A/C compressor clutch or the entire A/C compressor? Does it need to come out through the wheel well or through the bottom?
The car has some front and rear end damage also. Does the trunklid need to come from a 1992+ Taurus donor car or will any Taurus/Sable trunk lid fit?
It seems that the engine runs fine, the clutch is new, and the ABS and airbag lights don't indicate any problems.
