Ok, not sure if this is normal, but when the a/c is on, you can feel at a steady rate, the a/c engaging and disengaging. It happens about every 15 seconds and causes the car rpms to jump and fall. Should it be that noticeable? Should it be happening that often?
The air gets super cold, so the the system is fine as far as everything else is concerned.
