a/c blower
txwindmiller
Texas
My a/c works great, but with it on full blast , I can hear the blower motor running wide open, but not much air out of the vents. The air out of the vents seems like it's on low speed. anyone else had this problem? Thank you
SASHO91
Zoom Zoom
San Antonio,TX
Sounds like a blend door problem... Try running a test on the EATC system (search for EATC Test).
projectSHO89
SHOless In St L
Be patient or get ignored... No one is here at your schedule's convenience, we all have our own obligations.
Either your evaporator core or your air inlet is blocked. Perhaps the ducting is disconnected behind the dash. If the condition is the same whether you're on MAX or not, it's probably the core is clogged with dirt. Sometimes, a critter will make a home in there....
Pull the blower motor and inspect the surface of the evaporator core.
Steve
txwindmiller
Texas
I was quoted $700 to pull the evap core today wow...He said you had to remove the dash is that right???
txwindmiller
Texas
Steve, is all I have to do is pull the blower motor out and I can 'BLOW OUT" the evap core???
Allan
jsho
Wisconsin
I have a similar problem, but mine will blow fine for a while then after a period of the air flow will minimize no matter what the fan speed is at. I can't seem to think what would cause this. I ran the EACT test and everything comes out ok. This must be rare because I haven't found much from searching. Any help would be great.
