99 headlights
ornery1
pa
i have a 97 and are faded i would like to replace them and found out today that the 99 has a different style??? can someone please post pictures comparing the 2. thanx
Glue Maker
The V8 Paradox
Sugar Land, TX
98-99
96-97
I have one of each but with the "browz" you can't tell. At least no one has said anything for the last two years........ Even at a SHO car SHO. :thumb:
Mr Anonymous
Tire Wall
See my post explaining the differences in the "modifying headlights" thread.
ornery1
pa
so basically it is just black instead of silver on the inside???????????
Glue Maker
The V8 Paradox
Sugar Land, TX
Yes sir, you are correct.
Edit----------
They dont have the horizontal adjusters, but you probably wont miss that.
Funmart6
my name is mud
Auburn, Alabama
While we are on the subject of headlights, what is a good method of restoring the clarity of the headlights,(other than the obvious solution of replacing them with new ones), anyone know of any good products for doing this that actually work?
Mr Anonymous
Tire Wall
As I mentioned in the other thread, the '99 headlights are coated differently -- I've never seen a '99 headlight turn yellow, or pit as badly as the '96-mid-'98 ones do.
All G3 Taurus headlights are interchangeable, there is no SHO-specific assy.
To clean headlights, get some very fine compound (3M with the blue Corvette on the label (NOT the red Vette)) about $4 at Walmart, and keep buffing and polishing. If you have really deep pits, wet sand with 800, 1200, and then 1600 grit sandpaper first, then polish with the compound.
wuzzzer
MN Moderator
St Cloud, Minnesota
On mine I used a bottle of plastic polish I got at Wal-Mart. Yellow bottle, pretty inexpensive. After a lot of elbow grease they look awesome!
NOTE - You will have to re-polish them every few months or so if you go this route.
