beemer
SHO NOOB
White '97 122K cams not welded. Gray CLOTH gut. Had to rewire somebody's **** poor starter installation. Transmission was overfilled, leaked down to proper level. One turn broken off left front spring. Clean and body in good shape except for ditch side sill plate (under the ground effects) shows some rust. This is worth fixin if I can find the sheet metal.
I bought it right. Everything works. I'd like to try and keep the SARC system functional however need to find driver's strut and spring, as strut spring perch has problems due to broken spring.
I'm way familiar with regular Taurii as I've been using them for daily drivers for years. This came up on my local C/L and I couldn't resist.
What I would like to know is if I cannot maintain the SARC system, what are the P/N's for moog springs folks here have used? Thanks in advance for your thoughts and advice. I am well aware of the cam issue....I found a video with sound on some SHO site labeled as pre-cam sprocket failure sound. My motor is dead quiet...sounds nothing like the video clip.... may risk this a while as welding from reputable shop near me is more than the cost of the car! :thankyou:
Best,
Paul
Username is the same I use everywhere. I was a BMW owner.. M6, 635CSi's, 740's etc. No more time for the bimmers.
Best,
Paul
