97 Lincoln continental= 96 Brake upgrade
Dustin89
Loganton, PA
I saw that a 95 Lincoln continental has the correct calipers, brackets and rotors. I found a 97 Lincoln continental at salvage yard and wondered if those parts would work with the upgrade on my 89 SHO. I would need 94-95 hubs off of any taurus correct. What do you do with the ABS stuff because my car has none being a 89?
Any help appreciated!
Thanks
Dustin
K-Dawg
Treasure Coast, FL
They should be the correct parts. The correct brackets will have FN74 stamped on them. You will need the knuckles from any Taurus or Sable, prefereably WITHOUT the provisions for ABS, although it really doesn't matter. The only difference between ABS and non-ABS knuckles is a small tab for the sensor.
Dustin89
Loganton, PA
Thanks for the reply.
I will have to go down this weekend for everything. Should not be that expensive.
Dustin
crystizel
