'97 ABS sensors on '94,now light on.
sethsho
Selah,WA.USA.
I broke the originals taking off spindles. Used set from wrecked Sable thinking they might be a better design. Brakes work well but ABS light constant. The newer set are plastic shells but same connections.
Do I need to reset/clear something,
or use original design?
Opinions welcomed.
Kevin Ryan
I would start by having someone clear out the codes and test drive. If the light comes back on you either have a problem w/the sensors from the Sable and/or a Pump Motor failure. Call Ford and ask for part #'s on your vehicle and the Sable.
crystizel
