96 Upgraded calipers
ryana83
Nashville, TN , USA
I am having the hardest time finding calipers that will work for the 96 Upgrade. I can't seem to find any with FN74 stamped on the brackets. I tried the Advance guys, and did not see it. Am I missing something important or are there no calipers in Nashville?
Thanks,
Ryan
wood_e
The dude
Ames, IA
Ask for calipers for a 95 lincoln conti. That way there's no dispute
HighSpeed
Low Drag
Chicago, IL
Fordpartsnetwork.com has them for $40/each with slider pins and boots included.
MorpheusGPR
Ford TRIO
Indianapolis, IN
Can I get an exact parts list for this? I need brakes and I have been having trouble getting everything as well. Seems as though there is confusion at the fords parts counter on what I need.
Also looked a lot more $$$ then I thought it would.
Thanks for the help.
Shoaz
Studly dood
Scottsdale, AZ
http://www.shotimes.com/SHO4_96brakepartlist.html
It's an old list, but the Ford part numbers are still accurate.
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
Maybe you should ask the guys that designed the original kit.
If you want the right parts, that work the first time, we've got them on the shelf.
voogru
Miami, FL
Any Lincoln Front Wheel Drive Or The Mrk8 4.6 Dohc Models Have The Correct Caliper Brackets Check The ***** For Some Crashed Lincolns
