96+ brakes/pad sizing
tampasho
tampa, fl
I'm doin the 96+ brake upgrade and need to know what size pads can be used. I know the 95 pads will work but can I fit pads made for the gen III?
I'm also planning on sending the rotors I bought out to SPmotorsports for the cadium plating in silver and maybe buy some KVR pads. And I still need the caliper brackets.
I figured the 96+ pads would be better since they would be larger but I dunno if they will work.
95 SHO
E
EX-SHO_man93
Guest
actually if i remember right the 94/95 pads are bigger than the 96+
Ryan
90 SHO Black on Black
aka 'Batmobile'
98.5 SVT Tour
Mods: Synthetic Turn Signal Fluid, Dialed In Kanuter Valve, Removed Muffler Belt, High Performance Johnson Rod, 300hp NAS System
9lb_SHO
home
hey tampasho what part of tampa are you from? i live in carrollwood. do you ever go to the car show at checkers on saturday nights? i have been looking for other SHO owners in the tampa bay area.
1993 ATX SHO with a few light mods:)
DeaconBlue
Cleveland, Ohio
No the '96 pads are bigger than the '94-95 pads, about 3/8" taller. Don't waste your time running the smaller '94-95 pads in the '96 setup.
'94-95 pads are DOT size D601
'96 pads are DOT size D598
95 MTX
with a few mods
tampasho
tampa, fl
Yea,
I just re-read the "Leigh Smith Brake Survey" on Shotimes and it talks about 94's being somewhat smaller.
So does anyone have any recommendations on pads? I was thinking KVR because I don't think Performance Friction has 96+ pads. The KVR's are pretty dusty from what I have read, anyone know?
9lb_SHO: I'll put a post up in Contacting Shoforum Members section.
Thanks all
95 SHO
Toolman
Boost it!
Grand Lake, Oklahoma, USA
well, I guess I never put them side by side. All I know is that when I got my pads, they had the same part for the 95 or the 96. BTW, I run PF pads in my 96 upgrade. They work great. Autozone had them.
NJshofear
Medford NJ
the 95 sho pads are the same as the 96+ slo pads. I had them side by side and they are much taller. you cannot run them (from i saw) on the 95 rotors. If your upgrade is to the 96+ sho brakes u are better off paying the extra for the sho pads. The size of the pads is y they brake so well.
Jeremy
Red 89 SHO
MODS:
-Upgraded brakes,
-17x7.5 Alesso Turbo(hyper black) wheels W/falken GRb fk451 tires (225/45/17)
-Custom bent single exhaust exiting under SHO on the back bumper
-Coilovers from IPT (not quite installed yet)
-Pioneer head unit, with 2 Rockford Fosgate 12inch subs, and RF amp, Alpine amp.
-Two row copper radiator
Coming soon: SFC, LSD, forced induction (twin-turbo or a S/C)
AIM:Tiedie6683
