95 SHO Front Brake Pads - Any
sperold
Last to Know
If you have not done the larger rotor diameter (294 mm or 11.6 inches) conversion, and want standard pads (276 mm or 10.9 inches), watch out!
All of the brake aftermarket companies lump the 95 SHO in with the 96 to 99 SHO. Order for the 94 model and things turn out better.
The part # must have 601 in it (for the 10.9 inch rotor).
They will give you a part # with 598 in it (fits the 11.6 rotor).
Happens every time, and all the vendors are wrong.
Ishodu
I have heard this a few times here in Canada. I am unsure if its the same in the USA or not.
sperold
Last to Know
Mine came from RockAuto in the USA. I think it is true in both places. The 94 listings are accurate (at least they tell you the large rotor size when they mention the 598 pads). It is the 95 listings that are too inclusive.
hawkeye18
Sorta cares
Norfolk, VA
You never want to order stuff from border years (95 and 96). There is WAAAY too much stuff that is mixed up in those two catalogs.
kidrock52
I pleed the fif!
Buckley, MI
I had a company send me 11.6" front rotors for my 95' and said that they had that down as stock. Rather than send them back I did the 96' upgrade.
