sperold
Last to Know
If you have not done the larger rotor diameter (294 mm or 11.6 inches) conversion, and want standard pads (276 mm or 10.9 inches), watch out!
All of the brake aftermarket companies lump the 95 SHO in with the 96 to 99 SHO. Order for the 94 model and things turn out better.
The part # must have 601 in it (for the 10.9 inch rotor).
They will give you a part # with 598 in it (fits the 11.6 rotor).
Happens every time, and all the vendors are wrong.
