187 SHO
95 mtx whats causing this short.(popping 10amp fuse)would the wire from starter or battery be bad? bad of starter where connections are.is loose.the battery cable causing this issue maybe.or wire from starter to fuse box?
accy feed or ign. its 10 amp.wire color is red with green stripe.i unbolted the underhood fuse box to check color of wire.if that helps describe it better.i wish i could find a written repair manual for this car.
