stangconcepts
I have a 95 MTX And had a tune up done and after that I have had no secondaries. If I run the thing up till the rev limiter kicks in it feels like the secondaries kick just before the rev limiter.I have checked for loose conections and bad vacum line with no luck. When you start the car the secondaries move from open to closed.Also I think I need a trans if you have one. Where the speedo cable go into the trans a chunk of the trans case is broke off.( And still attached to the cable)
When this happened there was a load clank and it slowed the car down bad then was free.Was this the notorius diff pin? Thanks for the forum!!!
