jspec23
Hey, I'm new to the forum, I have a question. Is there any way to tell without looking as to which kind of tranny i have, cable or rod shift? I've got a 95 mtx, w/ a 3.0L. I looks like there is a big price difference between the two. I plan on fixing it myself. For the past two weeks about, i've been hearing a metallic rubbing noise whenever i applied pressure to the clutch pedal. It wasn't real loud, but it was noticeble. Then friday i was on the highway, i took the car out of gear, released the clutch, and heard an awful metallic noise ( ching ching ching type of sound) it stopped, after a few seconds, and the car went back into gear with no problem.Well, later on that night, i was on my way home, got off my exit, put the car in nuetral again, heard the noise, then my car satrted to slow down, and the engine died. i rolled ff the exit to a side street. pushed the clutch in, the car started, was still in Neutral, let off the clutch and it died. tried to go forward in first, would not move, smelled clutch. The car rolls in neutral if the car is not running, and it rolls when the clutch is pushed in, it just won't run in neutral, or move at all when in gear. So does this in fact sound like a tranny problem? Or could it be a bad TO bearing or something? Any help would be appreciated.
As for your stalling problem im not sure what it is, does it grind when you shift gears? when my synchronizer went in my tranny it would grind as it was put into gear but i dont think thats your problem. More expeirenced people here will give you far better advice, good luck!!
