95 atx hesitates off the line
brandon1186
ontario
My 95 atx sho has just started hesitating off the line, once the rpm's go up then its fine or if i hammer it from a 20mph roll it pulls like crazy it only does this from a dig . I was thinking maybe the tps or cam sensor,or plugs and wires? I have no codes what do you guys thinks? thanks in advance:)
CademiaX
What's an SHO?
Utah
are you bogging it on take off? I typically hit about 1500rpm+ before I take off and don't drop below 2000rpm after that
brandon1186
ontario
its a atx, it used to bark the tires if i punched it now it takes off slow as **** till around 3000rpm then it pulls ?
CademiaX
What's an SHO?
Utah
OOH, maybe I should read a bit closer next time :)
I think I would maybe check the fuel pressure. That also happens to me when I am running pretty close to empty.
SHOtimer
#2910
Santa Clarita, Ca
When is the last time your vehicle had a 60k service? (timing belt, spark plugs, wires...ect.)
Have you checked your codes?
Try unplugging your MAF and see if that makes it better.
Doug
brandon1186
ontario
i did the 60k around a year ago but never changed the plug wires so i will try that also there is no codes
brandon1186
ontario
no oil in the plug wells i changed the plug well seals when i did the valve cover gaskets. I used champion spark plugs. from a roll the car screams and pulls like crazy only off the line it falls flat on its face.
