95 atx engine problems please i need help
DirtySho
indiana
95 atx
engine starts up fine after a few minutes it starts to idel very rough.
and also its i think missfirein on driver side exsaust only.
and its makin a gurralin sound and bogging down really bad. anyone help me please!!!:shrug:
sperold
Last to Know
Every time the intake is off and reinstalled, it is a good idea to check for vacuum leaks and make sure your Distributer-less ignition system (DIS) module is grounded properly to the crossover tube and the tube must be well grounded to the firewall.
These are nice free fixes, and they go a long way to having a fine running SHO.
DrivinFast
NY
are you sure all of your spark plug wires are in the correct orders? All of the manuals have it printed wrong.
which one is the "driver's side exhaust"?
sperold
Last to Know
Need more information, and maybe close the emergency topic as it hard to know which one to reply to.
Your symptoms could be as simple as pressure washing your motor and getting water in your spark plug wells.
If you will answer a few questions:
Has the intake been off?
Have the wires been off all at once?
Have the plugs been out?
Have you looked for oil or water where your plug sits?
Did you "wash" your engine?
What have you replaced lately?
Do you know how to get the stored codes using a paper clip, or do you have a code reader?
Without doing anything else, answer these questions and give us something to work with.
DirtySho
indiana
yes the intake has been takin off many times for tune up and repairs.
yes the wires have all been off at once. but put back in the correct order.
yes the plugs have been out whe they where changed and just last night to make sure that they all good.
yes there was oil in the plug wholes before tune up 2 months ago. i cleaned it up before i put new ones in.
yes it has i hand washed it. with engine degreaser and a rag. no power wash.
i have replaced all the spark plugs, all the wires, all intake gaskets, valve cover gaskets, spark plug gaskets, the long neck valve stems, the rubber connecters on intake manafold, all fuses, new esaust true duals, throttle body gasket and i put a coldair intake with a cone filter.
no i dont know how to get the codes with a paper clip.
DirtySho
indiana
yes the intake manafold has been takin off many times for car repair.
yes the wires have all been off at once. but put back in the right order.
yes the plugs have been out and they where check and change 2 nights ago.
yes i did look for oil and water and there was oil or water in the plugs holes.
yes it has been washed before but only by hand no power washing.
i have replaced all the plugs and all the wires, all upper engine gaskets including head gaskets, throttle body gasket, changed the cold air intake to a intake with a cone. and i put the cone intake back into the airbox, i put a true dual exsaust on aswell with an x pipe. new long kneck vavle stems,and a welded cams.
no i dont know how to get the codes with a paper clip. i dont have a code reader.
