95 ATX Engine/Parts: NEED TO SELL ASAP!!
Status
Not open for further replies.
95mtxsholove
Staten Island, NY
Engine has 109k miles. Willing to sell entire block if offered the right price.. or will just part it out.
IF YOU DON'T LIKE THE PRICE LISTED, MAKE ME AN OFFER!
[Need to sell ASAP!]
...also have an entire car for sale. 95 Green ATX. If offered the right price, will part it out... [ad in SHOTrader]
Parts Listed Under Picture (took cover off to show pulleys):
SHO5
-Engine Block 3.2 [w/ pistons]: $150
-Engine Wiring Harness: $50
-Heads [3.2 in Good condition]: $175
-Valve Covers: $35 for the set
-Motor Mounts [In Good condition]: $30 for the set
-Throttle Body: $25
-Mass Air Flow [MAS]: $30
-Coil Pack: $30
-Coil Pack Bracket: $10
-Coil Cover: $5
or complete: $40
-Starter: $35
-DIS Box: $30
-All pulleys: make offer
-Crank Sensor: $10
-Cams [4]: $10 each
-Camshaft Sensor: $10
-IAC Sensor: $10
-TPS Sensor: $25
-Oil Pan: $35
-Oil Pump: $10
-Water Pump: $20
-Air Filter Box [stock]: $15
-Air Filter Sensor: $5
-Fuel Rail: $20
-Fuel Injectors: $20
-Power Steering Pump: $40
-Power Steering Bottle: $15
-Headlight
: $25
-Sunroof Plastic Cover: $10
-Amps [Stock]: $50
-Aftermarket CD Changer [w/o magazine]: $60
-Aftermarket Radio [Pioneer]: $40
Art5
white plains, NY
How much do you want for the engine minus intake manifold,motor mounts, some accessories?
zak
east of Hartford
DIS (depending upon part number on it) and 3.2 oil pump are of interest - zak
N3FOL
Pennsylvania
Pulley
SHO5
-Throttle Body: $25
-Coil Pack: $30
-Coil Cover: $5
or complete: $40
-Starter: $35
-DIS Box: $30
-Crank Sensor: $10
-Cams [4]: $10 each
-IAC Sensor: $10
-TPS Sensor: $25
-Oil Pan: $35
-Oil Pump: $10
-Water Pump: $20
-Fuel Rail: $20
-Headlight
: $25
-Amps [Stock]: $50
I need a Power Steering Pulley, asap. Do you one available? I'm in PA.​
Status
Brad kirk
