I have a 95 3.2 sho. About a month ago I noticed that it was starting to feel a little sluggish and it gradually lost more and more power, untill one day it just barely made it home. It has 140k on it so I thought that I would give it a tune up and it would be back on the road.
recently changed the camposition sensor, and I get a tach reading when cranking.
so I bought some plugs and wires and, it wont start.
checked wire sequence and everything is in the right order.
changed coil pack - still nothing
changed Dis module - still nothing
changed MAF...nothing
I checked spark at the plugs and the plugs are firing a nice bright spark.
fuel pressure! nope 40+ psi, and I jumpered the fuel pump so that it runs continuously to rule out a relay problem, and still no go.
So any suggestions?
*If I floor it when I try to start it the rpm's speed up, and sometimes will just barely start for about a second then quickly die.
clogged cats?
bad injectors??
timing???
THanks, any help is appreciated
So any suggestions?
clogged cats?
bad injectors??
timing???
and can you post pics?
