'94atx won't idle/new pressure reg.
'94SHO
Towley rules!!
R.I.
:type: my 48 hour old 94atx started stalling at lights, this progressed into a no idle condition,engine ran good over 2500-3000 rpms. Replaced the fuel press. reg. due to 20 psi at idle. Now 32psi at idle, 40 psi at WOT. turned the throttle stop screw in 3-4 turns to get it to idle. sometimes it idles at 2500, sometimes 750 rpms:bonk: Now I shift it manually, and sometimes push brakes and gas, and nuetral at the lights to keep it from stalling. Runs GREAT at freeway speeds,or during WOT ( just ask that Maxima!):lol: :smash: ...... SO, IAC, or cam sensor?:laugh_ti: This is all after rotors, pads, sway bar links, all filters, mobil one fluids..... OH! the '96 aic valve is like 1/2 the price... I can use it, yes?
SASHO91
Zoom Zoom
San Antonio,TX
are you sure your'e looking at the correct plug? There are two back there, one for the EEC and the other for the ABS.
Allthough, all you need to do to fix your problem is either clean the IAC or buy a new one (don't think the 96up IAC will work).
