94 running bad
jon93
Philadelphia Region
i know two fuel injectors are leaking, the car is running unusually horrible. the codes coming up are 124 TPS voltage high,157 maf low,216 coil #2 primary circuit fault, and 332 EGR valve not opening. all suggestions would be a help.fuel injectors are on their way and i got new plugs and wires to for it.
jon93
Philadelphia Region
All the fuel injectors are good now and the codes are all gone, no check engine light.but my idle is at about 500rpm and #2 cylinder is not firing.i think it is either the computer,dis,or that other computer thing next to the coil.anyone have anything like this happen, my SHO is running crappy :cry:
projectSHO89
SHOless In St L
Work on the misfire. If you have confirmed that it is ONLY the #2 cylinder, then you're looking at a plug, wire, injector, or valve.
A DIS or coil fault will take out another cylinder with the #2 - #6.
Steve
