94 mtx top engine knock? With video link
Vancouver Bc
Hi guys
Here’s a doozy.
So I have a 1994 Ford Taurus SHO Mtx that has a top engine knock. it knocks more as the RPM is increased. I have taken a stethoscope to it and pinpointed the location not exactly but roughly.
I am now currently looking into nearby parts stores to see if they sell gasketsValves valves springs etc. etc. for when I do open the top end to investigate.
I have also taken off the maf and air intake just to investigate and when I had it running I noticed a bit of exhaust come out of the throttlebody so I’m leaning towards that it might be a valve lash possibly on the exhaust port maybe a loose valve spring or just a worn out valve spring. It could even possibly be piston slap on the valves itself and the top end.
I’m still new to these engines I do have an adequate amount of information in manuals to understand the tear down and rebuild butI thought I’d reach out to you guys to see what you guys might think of it. Maybe this is happened to you guys before.
I do have a video of it here is the link
If you guys have any tips tricks and or ideologies of what you might think this could be please let me know
Anything and Everything is much appreciated
Thanks in advance
Irish Pride
Irish Inside
MusicCityUSA
Sounds like you have a failed timing chain tensioner. Is the noise coming from the drivers side of the intake?
These engines are non interference so the piston is not contacting with the valve and if you had a broken spring the engine wouldn't be running right now. Pull the intake and valve covers and I'll bet that you will see what's wrong right away.
Vancouver Bc
BB126E09 BF12 4138 8A75 3DFCD866F482
Front chain tentioner
0B8A85FA DDEC 4BD7 841E 760B916B7374
Rear chain tentioner
8AAA286E E2F6 484A B486 85506EFEA92E
Rear cams cylinders 4,5,6
2ED6CE15 781D 4AE2 9FA2 CA85850CC49A
Front cams cylinders 1,2,3
Thanks Irish
The noise was coming from the drivers firewall side/end. Mostly thinking it is coming from cylinders 5/6.
I have taken the intake manifold off and the valve cover to investigate.
As far as I can see is the isn’t anything obviously wrong with either the exhaust cams or the intake cams or anything else under the valve cover for that matter.
Everything was clean, tight, lubricatedand all looked fine.
I then proceeded to rotatate the engine manually from the crank to inspect the rotations and see if there were any obvious signs of damage or wear etc..
Everything thing looked perfectly normal
At this point I am having to dig deeper into the tool bag.
I think I’m going to try a leak down test
Do some more research on cam removal chain removal valve removal etc..etc..
Let me know what you guys think
Thanks again
Vancouver Bc
BB087E29 CD09 497E B3BA B6E3CE371780
This tensioner seems to be a bit loose but not by much I think. I will look into the specs for tensioners. Also this one wasn’t near the location of the sound when I used a stethoscope. This was the front valve cover piston 1/2.
Does the timing belt seem to be under proper tension? Does it look like the belt could have been slapping the inside of the timing cover?
This is quite possible, I only have the range of a pry bar rotating the crank. C57137EE 7340 44F2 9724 4D0C0500C929
This is the rear cam chain cylinder 5/6 which has a different setup then the front and was pretty tight to the touch .
I still have to do some reading up on chain timing and replacement intervals for tensioners etc..
I will investigate more on any slapping marks or abrasions.
Also I will be attempting to remover the pan if possible to check the bottom out for filings sludge etc.
The manuals I have aren't too specific to this procedure.
Thanks again
Irish Pride
Irish Inside
MusicCityUSA
The timing chain tensioners are oil pressure activated so there will be some play in them with the engine not running.
The rear tensioner points down so you will need to remove the guide to get a good look at the tensioner.
Vancouver Bc
Hmm i guess I have to put it all together and run it to get oil pressure.
Is there an external gauge to read oil pressure? I mean I know I can get a cluster gauge for pressure but is there a tool for it?
Does it work like compression? Per cylinder?
Or oil pressure as a whole oil unit?
I have been told to try a leak down test and a compression test as well
I haven’t had a chance to remove the pan for investigation but I might do that soon
Thanks again
Usually, you remove the oil pressure switch and install a gauge to read oil pressure. Between 0-100 psi should be quite sufficient.
The pan is sealed with RTV, so be prepared for that. Timing tho as mentioned above sounds very likely at this point. If the idiot light for oil pressure was not blinking, you are probably ok in that department for now.
M Brown
NC
Hi guys
Here’s a doozy.
Thanks in advance
I was looking at video on U Tube the sound it was making was close to what yours is doing and it turned out to be a rod bearing.
hosbaldosho
