94 atx having problems starting
raul916
florida
i jus recently bought a 94 atx with 70k miles, car runs perfect except for the fact that it gives me problems starting at normal operating temperature. it sound likes it wants to start but wont until ive been trying for a few minutes. i already replaced the ignition coil, wires, plugs,ignition modules and fuel filter (all parts were new taken from my other 94 atx). also when it finally does start it sounds like a very bad misfire from the cylinders and turns off unless im flooring the throttle. im thinking it has to be a sensor or something because i have no misfires or anything else when the cars on.
any ideas?
94 atx green 160k miles, 94 green atx 70k miles
raul916
florida
i also forgot to say that when the car finally does turn on the tach needle wont move for about a minute then start functioning normal
Pull the codes and let us know what they are. see shotimes.com if you need details on that.
There are a number of common issues that cause those symptoms, so codes are important to save you from throwing money at it.
raul916
florida
i really jus need to find out what the problem is, as far as throwing money at it i have another 94 atx that i can jus take whatever parts i need off of that. ill check the codes tomorrow and post what it tells me
Wakeboy1337
GTPGTPGTPGTPGTP
Cape Cod, MA.
Mine will do this too once in a great while. I've narrowed mine down to these.
Bad wire in the harness for the Crank position sensor.
Bad ground on DIS module( I'm taking care of that before I reinstall my intake)
Bad cam shaft sensor(It is the same one the car had when I first saw it)
I would check all of those things first.
Mine will do it hot or cold, but hardly ever. To get it to run all i do is jiggle all my wires like a lunatic and it will fire right up (usually with no rpm gauge) and I get the car moving again before it stalls out and then the need will jump up to whatever rpm is at.
shofreddy
Minnesnota
My symptoms are similar but my tach works fine.. had the ICM checked and came back good, also grounded it.. sometimes it starts right up and idles fine then all of a sudden..... Dead!!! should i check the cam and crank pos sensors?
thatSHOguy101
