94-95 spindles???
92silverbullet
wi
to do the 96 up brake upgrade i know you can use 94-95 sho spindles but what else can i use?? Can i use regular 94-95 taurus sable, gen 3 non-sho , regular sable.??
93rev2sev
Hockeytown
The only thing to be sure if is that it has ABS....unless you want to delete ABS...like me.
94-95 Taurus/sable any model with ABS
continental spindles might work
windstar spindles might work.
I'm pretty sure all listed models will work.
92silverbullet
wi
missing pieces.
But the rotors, calipers and brackets from the gen 3 is what is needed.. corrrect??
Storm-Chaser
Shit Louis
This information has been posted here repeatedly. Use the search function above, as the various parts required can come from a number of different vehicles, spanning different model-years starting in 1993. I don't have time right now, but will check back late this evening to see if you've found the information, after work.
thatSHOguy101
