93 Surge at part throttle
whitrock
Tennessee
93 Mtx does not surge at idle. Surges upon acceleration & part throttle{crusing in 4th gear about 45mph}. It does not do it with ac off. I cleaned the maf & throttle body{on car}. Had po521 power steering pressure sensor. Replaced still same thing. It's not as bad in higher gears. It almost feels like the compressor is cycling...checked it ok. I did 60k service about 8000 miles ago. Replaced crank & cam sensors in the service.
TYSHO
Earth
Have you checked your fuel pressure? It can be a weak pump needing replacement.
