More Shifting Problems! Original clutch/engine w 93k. Generally runs great. I've had hard shift into first and reverse, but it really helped when I got a few shifting tips(quick shift into first, aligning syncro's by shifting into N then 4th before reverse). Also recently changed the MTX fluid with full synthetic(may have to do with new problem). I was able to get an extra 'click out of clutch adj. around the time I changed fluid, and cold and short drive shifting was mutch better. Just drove it to Chicago- It was hot from hwy drive then got caught in traffic and it got harder and harder to shift. eventually had to start from second (still difficult) and felt like transmission was still pushing (Pulling?) car when clutch pedal was on the floor. However, gears were never grinding, it just took all my strength to push into gear. Next morning shifted much better when cold. I'm thinking 1. wrong trans fluid (heating up and thinning causing hard shifts. 2. clutch cable streaching maybe worse when hot? I'll change fluid, any other suggestions? BTW Roger Waters 'the wall' at united center made whole trip worth it.
