the4biddendonut
Hurry up meow.
My 93 ATX SHO isn't charging the battery for some reason. I was driving one day and the battery light turned on and eventually I ran the battery dead. So I pulled my alternator and had it checked at Pep Boys and they said it was a bad alternator. I replaced the alternator, battery cables, alternator cable and the ground strap all at the same time and now it does the exact same thing. I charged the battery and drove it for about a day, and eventually the battery ran dead again.
I'm at a loss as what to look at next. All I can think to do is check the connector on the alternator, but I'm not sure what to look for. How can I tell if the connector is and the wires are working correctly?? Should there be a voltage? and which wires should have voltage and when should they have it?
Any help will be appreciated.
