antz
I keel you
Sold
its time for me to part ways with my sho. Its a 92 white mtx with the white rims, and gray full leather interior.
http://www.flickr.com/photos/80053796@N06/7337415440/
http://www.flickr.com/photos/80053796@N06/7337414164/
http://www.flickr.com/photos/80053796@N06/7337412142/
http://www.flickr.com/photos/80053796@N06/7337410860/
http://www.flickr.com/photos/80053796@N06/7167517745/
http://www.flickr.com/photos/80053796@N06/7352727856/
http://www.flickr.com/photos/80053796@N06/7352727296/in/photostream
http://www.flickr.com/photos/80053796@N06/7167516093/in/photostream
http://www.flickr.com/photos/80053796@N06/7352726230/in/photostream
http://www.flickr.com/photos/80053796@N06/7352725678/in/photostream
http://www.flickr.com/photos/80053796@N06/7167514475/in/photostream
http://www.flickr.com/photos/80053796@N06/7352724578/in/photostream
http://www.flickr.com/photos/80053796@N06/7167513383/in/photostream
http://www.flickr.com/photos/80053796@N06/7167513029/in/photostream
http://www.flickr.com/photos/80053796@N06/7352723334/in/photostream
I am the 3rd owner. the previous owner gave me all recipts for work they had done. i got the car with 134K on it. it now has 174K i have had the car for 4 years it was my daily driver but mostly to and from work.
work that has been done since i have had the car is
-new fuel pump sending unit and filter.
-60K service, new plugs, taylor 8.2 wires, and accel ignition module.
-new tires last year only about 10K miles if that on them they have a lot of life left.
-watr pump twice, and thermostat.
-ported intake manifold, and bbbs
-new battery
-sho source udp with new belts, tensioners have new bearings as well
-timing belt, and tensioner.
-alsfb
-monroe sensa trac struts, springs, new mounts, new bushings, front and back.
-lower control arms.
-jose short shifter installed. not the good one his second batch one.
-front strut tower brace.
-96 brake upgrade bearings in knuckles have about 15k on them.
-2nd gen spoiler with working brake light.
-2nd gen center console
-new used driver side window switch, old one stopped working.
-o2 sensors
-magnaflow y-pipe
-dynomax cat back exhaust
-new rear strut rods with new bushings
-new e-brake cables, all 3
-new calipers, rotors and pads in rear.
-rod bearings
-oil pan gasket and oil pick up tube gsket
-front main seal and rear main seal.
-clutch (sho nut heavy duty clutch kit with ceramic bearing), and resurfaced flywheel
-trans fluid changed
-new end links front and rear.
thats all i can think of right now i might of missed a couple things.
the things that are wrong with the car.
-cam seals are starting to seep. there not leaking bad at all I have the gaskets just havent put them in. there not the felpro ones either.
-the abs light is on its been on since i have owned the car. i've never had a problem with the brakes. i've never looked into it.
- the driver side seat has some normal ware and tare, the boltser and back have tares in it.
-the paint has some chips on the hood.
- and the a/c does not work, i dont care for a/c so i never looked into fixing it.
other then that the car is in good shape. I would get in it and drive cross country now wihtout a hesitation. I just recently got another car and this one will not be getting used. there is no rust on the outside of the car where the usual rust occurs. asking 1200.
-new battery
-alsfb
-o2 sensors
-magnaflow y-pipe
-rod bearings
