92 white mtx
antz
I keel you
new jersey
Sold
its time for me to part ways with my sho. Its a 92 white mtx with the white rims, and gray full leather interior.
http://www.flickr.com/photos/80053796@N06/7337415440/
http://www.flickr.com/photos/80053796@N06/7337414164/
http://www.flickr.com/photos/80053796@N06/7337412142/
http://www.flickr.com/photos/80053796@N06/7337410860/
http://www.flickr.com/photos/80053796@N06/7167517745/
http://www.flickr.com/photos/80053796@N06/7352727856/
http://www.flickr.com/photos/80053796@N06/7352727296/in/photostream
http://www.flickr.com/photos/80053796@N06/7167516093/in/photostream
http://www.flickr.com/photos/80053796@N06/7352726230/in/photostream
http://www.flickr.com/photos/80053796@N06/7352725678/in/photostream
http://www.flickr.com/photos/80053796@N06/7167514475/in/photostream
http://www.flickr.com/photos/80053796@N06/7352724578/in/photostream
http://www.flickr.com/photos/80053796@N06/7167513383/in/photostream
http://www.flickr.com/photos/80053796@N06/7167513029/in/photostream
http://www.flickr.com/photos/80053796@N06/7352723334/in/photostream
I am the 3rd owner. the previous owner gave me all recipts for work they had done. i got the car with 134K on it. it now has 174K i have had the car for 4 years it was my daily driver but mostly to and from work.
work that has been done since i have had the car is
-new fuel pump sending unit and filter.
-60K service, new plugs, taylor 8.2 wires, and accel ignition module.
-new tires last year only about 10K miles if that on them they have a lot of life left.
-watr pump twice, and thermostat.
-ported intake manifold, and bbbs
-new battery
-sho source udp with new belts, tensioners have new bearings as well
-timing belt, and tensioner.
-alsfb
-monroe sensa trac struts, springs, new mounts, new bushings, front and back.
-lower control arms.
-jose short shifter installed. not the good one his second batch one.
-front strut tower brace.
-96 brake upgrade bearings in knuckles have about 15k on them.
-2nd gen spoiler with working brake light.
-2nd gen center console
-new used driver side window switch, old one stopped working.
-o2 sensors
-magnaflow y-pipe
-dynomax cat back exhaust
-new rear strut rods with new bushings
-new e-brake cables, all 3
-new calipers, rotors and pads in rear.
-rod bearings
-oil pan gasket and oil pick up tube gsket
-front main seal and rear main seal.
-clutch (sho nut heavy duty clutch kit with ceramic bearing), and resurfaced flywheel
-trans fluid changed
-new end links front and rear.
thats all i can think of right now i might of missed a couple things.
the things that are wrong with the car.
-cam seals are starting to seep. there not leaking bad at all I have the gaskets just havent put them in. there not the felpro ones either.
-the abs light is on its been on since i have owned the car. i've never had a problem with the brakes. i've never looked into it.
- the driver side seat has some normal ware and tare, the boltser and back have tares in it.
-the paint has some chips on the hood.
- and the a/c does not work, i dont care for a/c so i never looked into fixing it.
other then that the car is in good shape. I would get in it and drive cross country now wihtout a hesitation. I just recently got another car and this one will not be getting used. there is no rust on the outside of the car where the usual rust occurs. asking 1200.
TimboSHO
Intermediate
Wyoming, MI
Sounds like a solid car. I can't see the pictures because they are private.
antz
I keel you
new jersey
sorry about that i changed the settings so it can be viewed. thanks for letting me know.
antz
I keel you
new jersey
Ya i hate to sell her but i just bought an s4 and the wife is pregnant and we have no need for 3 cars.
dohcsable
Gold Calipers>*
Indiana
Thank god I don't have the extra $$$ right now......good looking car, hope it finds a good home.
Irish Pride
Irish Inside
MusicCityUSA
Good deal, not a bad looking car either. Any pics of the interior damage.
antz
I keel you
new jersey
I didn't take any pics of the interior I could take some just for ***** and giggles. only teh driver seat is has some tares in it and its nothing compared to some cars i've seen, and owned.
