'92 SHO Roof Problem...
Zap
West Bend, Wisconsin
Well, if you've seen any of my other posts, I'm currently negotiating over a '92 MTX, and I had a couple body questions.
Somehow, the roof of the car has a mid-sized crack on the outside, but it doesnt leak inside. Is there any way to fix this crack (seal and paint), or even replace the roof panel? Also, could a roof panel with the moonroof replace the non-moonroof panel? I've been attached to the idea of a moonroof, but this car doesnt have it. What would the cost be for repair / replacement?
On a sidenote, the hood has a small crack in the front, is there a way to seal this crack? It looks like it could be filled and painted, as there is a small gap. This is compared to the roof, which is more cracked, but without a real gap.
Thanks,
Zap
munkee
Too busy...
Missoula, MT
Is the crack in just the paint or is the metal separating? If the metal is separating, I would be real curious as to why (possibly a previous rollover and second rate repair) and where else ( subframe \ underbody) it might be cracking. It usually takes a lot of serious vibration to separate sheet metal. If the metal is cracked painting it to seal it won't do any good because vibrations will cause it to crack again. You can replace the hood relatively easily. If the crack is in the right place on the roof, you might be able to cut it out by installing a moonroof.
Zap
All I know is that I've checked out CarFax and I didn't see anything anywhere near to a rollover. The crack in the roof has a white color in the split. (The car is black) I'm not sure what else to mention, but any extra help is appreciated!
RickieFrat
La Cosa Nostra
State of Corruption - RI
Is it possible for you to post a pic for us to see how it looks ??
1992 TAURUS SHO
Sig Pic By SHOTIME (THX)
MORE INFO AND PICS
1988 T-bird Turbo Coupe
Needs lil' work. Soon-to-be drag car.
AIM ... fst92sho
FRAT'S PERFORMANCE.COM
Your One Stop Source For ALL Your Audio Needs
Zap
I can see if I am able to borrow a digital camera. That may be more helpful in determining the seriousness of the problems.
Zap
