92 sho dash lights
d2freak82
Kansas
Alright so I just bought my first sho, damn damn lights don't work, I've tried the dimmer and all the fun stuff. If you turn the interior lights on with the dimmer switch dash lights come on, but when they're off no go...
I don't have a fuse cover so I can't tell which fuse is what, but I checked all of them, only one was bad was the radio and I replaced it and also fixed the problem.
Some retard cut the radio harness, which I repaired thinking it might be the issue but it's not plugged into anything because it didn't come with a radio, I'm not sure the lights have much to do with it but I've seen it cause problems on other cars.
Any ideas what to do?
Art5
white plains, NY
weired issue. check if your fog lights shorting out. But that would be through one of the fuses though.
