92 mtx transmission
trevhelton
Yakima, Washington
What are my option for a replacement transmission. Can I run any ford transmission or a certian mazda one. Or better yet is there as upgraded transmission with better gear ratios and possibly six speeds.
thecrew2999
3.2 MTX SHO
Harrisburg/WilliamsportPA
you blew the diff pin im guessing..
well no one has tried anything in the likes of using a different transmission yet... the only real info i can give you is get any 89 - 95 taurus SHO 5 speed since it will match up.... also weld the diff pin at least....
do some experimenting and use a different transmission do what others dont try..
also please change your rod bearings or you will be asking about a engine next...
AREA 91
PA SHO SHOP
Area 91
Nope.
You need an 89-95 Ford Taurus SHO MTX4 Tranny.
The average replacement price right now seems to be $350-$400.
Please post a pic so we can better understand you're delema.;)
Kens1992mtxSHO
The Commonwealth
It doesn't sound like he needs a new transmission as much as he wants one. 6 forward gears would be nice but sadly it cannot be. :cry:
trevhelton
Yakima, Washington
Unfortunaly I am not going to be able to post a pic it has been temporary repaired till I can hunt down a new transmission. So I am looking into my option of what will work and if there is anyways that I can upgrade this part no reason to change a part that is not broken unless I have money to blow which is not the case. So I would like to change what I can while I have ae excuse.
tinkerkathleen
