92' MTX Hard Starting?? Help Please
SHO04093
Buxton,Maine
Hi I have a 92 Sho MTX with 137,000 miles on my car i havent had this car very long, BUt when I first bought the Car it started everyday right on the money. I just recently added a new Exhaust System by Dynomax and seems that ever since then it Starts like a pig??? And when It does Start after I drive it and it is warm when trying to restart warm it is very hard starting also? It does have a Check engine light on. I am going to take it to have the code read for some info into it but was wondering if any ideas you could throw out at me to think about please. It does have a K&N cone Filter that is Installed on this car from a previous owner. Not really sure if this would cause any issues at all? any help would greatly be apreciated. Thank you very much for your time and information
Calypso
**** Deer
Grand Rapids, MI
SHO04093
Buxton,Maine
I Pulled The Codes Please help
Ok I was able to pull the codes. And they are as follows a code 214 CID Circut Failure. And a Code 542 Fuel Pump Secondary Circut Failure. If anyone could help with information conating to these Codes i would greatly apreciate it. Thank you very much
Calypso
**** Deer
Grand Rapids, MI
I have head that the fuel pump code doesn't mean anything, so you shouldn't need to worry about that. But then again, that may be causing the hard starting. Do you hear the pump hum when you turn the key on? If not that may be the problem. The CID is probably the more likely culprit here, from what I have heard. Check for a water pump leak, which frequently causes a CID failure.
jedhead
westminster,ca
Usual cause for 214 code is the camshaft position sensor. IIRC is on the rear exhaust cam on the passenger side. It identifies where top dead center on cylinder on is on start up.
Bob
SHO04093
Buxton,Maine
Fuel Pump does come on/Whats IIRC??? mean
Thank you for all the information guys. The fuel pump I can hear come on and after trying to start it a while i can smell the fuel. Not to sound dumb but i am trying to learn this vehicle and all the lingo but Jeghead you had some really good information too But what does IIRC mean? Is that the cam shaft position sensor? Thank you so very much for all the information guys.
jedhead
westminster,ca
IIRC = If I Recall Correctly.
Bob
SHO04093
Buxton,Maine
New code 213?? After replacing the cam postioning sensor
Ok i went a herad and replaced the cam positioning sensor ok. Now it still wont start and I have a new code???? 213 any more help would be great thank you so very much. I can hear the fuel pump come on . Thank you again for your time and help
SHO04093
Buxton,Maine
Ok, thank you again for all your help. Now the code is reading 3 3 1 3 3.
Does anyone have any idea what this means?
thank you in advance
SHO04093
Buxton,Maine
It's Alive!!!!!!!
We'll jedhead Thank you for the info i did what you said and she starts right up fine now wow thank you. She is purring like a kitten thank you for teh time and the info. And to all those who helped thank you.
