91sho starter solenoid need a picture or help
john p
I want to thank everyone that helped me on my last thread I got the sho up and running but now I have some other issues now my battery keep dieing if I let the sit a couple of day so i need to fix this so i figured I would start with the starter solenoid to make sure I have all the wires on the right part of the solenoid I'm having trouble reading the schematic I was wondering if someone could help me and post a picture of their solenoid with the wires connected to it so I can see what wires go where
john p
Also if anyone has a diagram of the vacuum system I would greatly appreciate that
pjtoledo
'ol man in the SHO
toledo,ohio,usa
How old is the battery? has the battery sat for long periods without use?
batteries that sit for weeks without being used can go bad. they seem to die of boredom, lose the ability to hold a charge.
charge it, then disconnect it and let sit for a few days. then try to use it and see if it went down by itself.
got a amp measuring meter? turn everything off and see if there is still current flowing.
CAUTION most amp meters can only handle low current, like 10 amps, so don't try the starter when its in the circuit.
john p
The battery is new so there a problem somewhere else when I bought the car it was totally ripped apart so I had to go through and try to figure out where everything went so that's why I wanted a picture of a starter solenoid with the wires attached that way I knew I had my wires hooked up on the right post how do I go about testing for a draw somewhere when my key is off
shootinirons
