Is there any detailed data on the X2J PCM that would be useable to customize the input signals I won't be using in the 914?
After talking to a SHO tuner it seems like the Ford PCM is not very "user-friendly." I'm considering just going with MegaSquirt II if adjusting the PCM is that much of a pain.
Here's the pinout list for the X2J I was planning to use on the 3.2. If it's better to stay with the ATX PCM, I'm willing to go that route.
Basically, it comes down to figuring out how to handle the input for the following:
There's gotta be a simple and reliable way to do this. Any first-hand experience would be helpful.
TIA
- #3 - Vehicle speed sensor (+)
- #5 - Brake on/off
- #6 - Vehicle speed sensor (-)
- #30 - Clutch pedal position switch
- #31 - Canister purge solenoid
TIA
