Ok, I changed the water pump, timing belt, and replaced the CPS. I set the timimg accordingly. All lines & notches lined up..
It will not start. For a split second it acts like it wants to if it sets a little while, but then nothing..I have the crossover tube connected. The only thing that is not connected is the other drive belts, and the timing belt covers..
I do have spark..
How can you pull the codes off these cars...?
Any fuse links that may be the cause?..
I'm at a loss....
Is there anyway that the timing can be off if the lines are right??
[This message has been edited by Cruez (edited 11-27-2001).]
I do have spark..
I'm at a loss....
