'91 Hesitation under WOT
9091SHOs
Pittsburgh
Hey Guys,
I am in need of some help. I have a '91 that is having a strange issue, when driving along at lower RPM (no matter what gear) if I go WOT the car hesitates and stumbles. The strange part is that if the car is above 3,000 RPM and I go WOT it runs great, secondaries open up and it will scream the whole way to 6,000 RPM. The CEL never comes on. I cleaned the MAF as it was somewhat dirty and it made no difference. I found out today, that I can simulate it from under the hood using the throttle body. From idle, I can pull the throttle body and it will rev cleanly, while coming down from the higher RPM if it hit the throttle body again it will do the hesitation/stumbling. Any help will be greatly appreciated!
zoomlater
Seattle, WA
yes, better to check and know what the car is telling you is wrong before throwing parts at it
9091SHOs
Pittsburgh
Agreed, wasnt sure if codes would be present if the CEL never came on. I will report back with codes once I get them. Thanks
zoomlater
Seattle, WA
That should be an easy fix, TPS sensor are relatively inexpensive. In fact, just bought few off ebay for $14 each
Jbeck
I have NO IDEA what I'm doing!!
Houston, TX
How dirty is the intake? Might be time to clean intake and IAB
