90 mm MAF?
jeanrw2000
Lechon Asado!
Brawley, CA
i just bought a lightning 90mm MAF from ebay, but i didn't come with the adapter ******. Does any of you guys were can i get one of those?
thnanks
Jean.
adidas_kn
LOWSHO
Houston Texas
You got that one with the SHO adaptor plug already on it for $100 didn't you? I was going to get that for my turbo project. Oh well. Yes SHOnut has the adaptor.
Later
"J"
jeanrw2000
Lechon Asado!
Brawley, CA
Later
"J"
i didnt get that one but in anycase they got more plenty if you click on that seller other items
:thumb:
jeanrw2000
Lechon Asado!
Brawley, CA
trueSHO said:
Sho nut I believe has them
the one shonut has sais is a little smaller althoug they say it will fit.
i was wondering if there is one specifically for their lightnings i would image that one being the proper size. maybe :shrug:
Axianator
I am a banana!
Roanoke, TX
The part number for the connector in question is SNP-LMAH, which is currently priced at $75 USD:
Lightning MAF Adaptor Harness
jeanrw2000
Lechon Asado!
Brawley, CA
i was in fact referring to the square plate adaptor that attaches the MAF to the intake pipe. The question was is there one for the lightnings that will fit better?. as per the one in the picture ( i know that it works but) its say to be a little undersize??
MAF adaptor
Axianator
I am a banana!
Roanoke, TX
Unless you have the means to machine your own custom ****** adaptor, Josh's 80mm MAF adaptor (which has a larger ID than the MAF outlet) is the only real aftermartket solution that currently exists for the Lightning 90mm MAF.
jeanrw2000
Lechon Asado!
Brawley, CA
thanks i didnt know that was the case.
i was actually looking a lightning last night and i learned that MAF is bolt it directly to the air box which i didnt know that is why i was asking about it .
thanks again. :thumb:
Jean.
TYSHO
Earth
I know it's a little late, but I've been looking into this myself and found 3" and 4" adaptor plates for $12.99 at PepBoys and AutoZone. However, I don't know if they work, but I know one had a couple different bolt hole patterns! :thumb:
jeanrw2000
Lechon Asado!
Brawley, CA
i saw those myself and i almost buy one but i took apart the one i had on my 80mm MAF and it fit perfectly, :omg: weird ah!
But, thanks for looking out man! :thumb:
Jean.
thatSHOguy101
